CMS panel hangs/freezes/becomes unresponsive after 2-3 commands
Working site is built on Umbraco version 7.5.4 assembly: 1.0.6136.27241.
After trying to save and publish every 2-3 commands/ updates on the CMS, it just freezes and doesn't save the updates.
Also the images saved on Media folders doesn't appear, and it always hangs whenever I try to select an image to upload on to a page, or even to navigate from one media folder to another.
Site is hosted on Arvixe hosting - I have already complaint multiple times, requested for server refresh and still no solution & the problem continues. Only solution i got is it might be a scripting problem.
Working site domain is http://pigeon.com.red.mysitehosted.com/.
Can someone help me on this please?
@Skiltz Thanks for responding.
We are using Umbraco v7.54 build image uploader on media section.
Initially the images are loading perfectly and media picker is well connected to Media gallery. It's been 2 days that this is happening.
No luck with Arvixe. They will just waste hours of your time leading you to the wrong solution - blaming ISP issues at that.
We are trying to deploy to a new server now. Hopefully it will get fixed naturally.
Working site is built on Umbraco version 7.5.4 assembly: 1.0.6136.27241. After trying to save and publish every 2-3 commands/ updates on the CMS, it just freezes and doesn't save the updates. Also the images saved on Media folders doesn't appear, and it always hangs whenever I try to select an image to upload on to a page, or even to navigate from one media folder to another. Site is hosted on Arvixe hosting - I have already complaint multiple times, requested for server refresh and still no solution & the problem continues. Only solution i got is it might be a scripting problem. Working site domain is http://pigeon.com.red.mysitehosted.com/. Can someone help me on this please?
If i browse some of your pages they seem to hang also.
If i try to browse to:
http://pigeon.com.red.mysitehosted.com/media/1103/pigeon-way.jpg?width=432&height=401 it hangs.
What are you using to process the images? I would start here.
@Skiltz Thanks for responding. We are using Umbraco v7.54 build image uploader on media section. Initially the images are loading perfectly and media picker is well connected to Media gallery. It's been 2 days that this is happening.
I'm sharing the filesystem.cofig codes we have:
We dont have separate security.config file.
I found this link online and our case is very similar, still i'm not sure - https://github.com/JimBobSquarePants/UmbracoFileSystemProviders.Azure/issues/57
Any help will be very appreciated.
Try redeploy to other server. If problem gone then maybe it's permission issue or something with Arvixe server.
Thank you for your response.
No luck with Arvixe. They will just waste hours of your time leading you to the wrong solution - blaming ISP issues at that. We are trying to deploy to a new server now. Hopefully it will get fixed naturally.
