System.ArgumentException: The parameters dictionary contains a null entry for parameter 'userId' of non-nullable type 'System.Int32' for method 'System.Threading.Tasks.Task`1[System.Web.Mvc.ActionResult] ValidatePasswordResetCode(Int32, System.String)' in 'Umbraco.Web.Editors.BackOfficeController'. An optional parameter must be a reference type, a nullable type, or be declared as an optional parameter.
From looking through Umbraco code, userId comes from the parameter 'u'. Clearly it has the value 2, so it's not null. Tried with other user ids and I still get the error.
Did anyone get a fix for this? I am getting the same on version 7.6.8
Parameter name: parameters
I get the same with Gmail, Outlook web app and standalone Outlook client
On a newer site on version 7.7.4 I don't even get as far as the form to fill in the email. I just get a box with Happy Manic Monday or funky Friday or whatever, so it doesn't seem that updating the version would be of any great help.
I solved the issue on the later version where the Manic Monday message is there but no form (turns out the form is there but just hidden in css due to a missing closing div tag)
ETA - I put in the missing div tag on a test site which worked - got the form, got the email, the url link worked. Then I tried it on the live site and the url failed with the same error as above. The test site is a direct clone from the live one, only a couple of days ago. Only difference I can think of between them is that the SSL. Could this be causing an issue?
ETA2 - yes it seems like the SSL is causing the problem.The link in the email is http://xxx.com/
But the website is set up on https://www.xxx.com/
So it's hitting the redirect through to https://www.xxx.com/ which is removing the querystring values.
Ok have this working -
Web.config appsettings: <add key="umbracoUseSSL" value="true" /> this was false. Seems to have sorted it.
Password reset link from Reset Password notification does not work
I have a problem with the link in the notification mail that is received after requesting a password reset. (I first had a problem receiving the notification, but that issue was tackled here: https://our.umbraco.org/forum/using-umbraco-and-getting-started/80908-umbraco-backoffice-forgotten-password-not-working).
Umbraco error log shows:
Umbraco version is 7.5.4 Thanks, Roelof
any fix for this, i am getting same problem: Umbraco v7.7.2
EDIT: working!?!
i had previously opened the email generated in a web browser, but when opened in Outlook, the link worked?
Bump!
Using Umbraco version 7.6.4
The link looks like this:
http://domain.com/umbraco/ValidatePasswordResetCode?u=2&r=6bV5....
I created an issue here:
http://issues.umbraco.org/issue/U4-10593
The parameters dictionary contains a null entry for parameter 'userId' of non-nullable type 'System.Int32' for method 'System.Threading.Tasks.Task`1[System.Web.Mvc.ActionResult] ValidatePasswordResetCode(Int32, System.String)' in 'Umbraco.Web.Editors.BackOfficeController'. An optional parameter must be a reference type, a nullable type, or be declared as an optional parameter. Parameter name: parameters
The url is:
http://www.xxxx.com/umbraco/ValidatePasswordResetCode?u=1&r=QYevFrQgT8TTPXZY%2B4gz6px415gfxI4JyLLxNbItwuIb7nLYXsqgyJqzK1tA26M1iEsDaqWV2oc%2FemYzSn3NTeogZQ%2BfO2gR5Q%2FkdCi2%2BDsThW%2BNNYr9qS%2BeXOdIVlYF12gdnTdypn%2F9buf6OaWnwg%3D%3D
The value for u does relate to the correct user.
Any help would be great, thanks
Ok thanks to this:
http://issues.umbraco.org/issueImageAttachments?issue=61-27810
ETA2 - yes it seems like the SSL is causing the problem.The link in the email is http://xxx.com/ But the website is set up on https://www.xxx.com/ So it's hitting the redirect through to https://www.xxx.com/ which is removing the querystring values.
Ok have this working - Web.config appsettings:
<add key="umbracoUseSSL" value="true" />this was false. Seems to have sorted it.is working on a reply...
