  • Matjung 2 posts 71 karma points
    Jan 19, 2017 @ 21:25
    Matjung
    Move Umbraco CMS from C:\Users\User\Documents
    Hi, if you just deployed Umbraco CMS with Microsoft Web Platform Installer, and never used WebMatrix before, you can move it to another location.
    Depending on your windows, the files ended up in C:\Users\User\Documents where you may not want to have it.
    You can move it from there to somewhere else. When you are in Umbraco CMS1 - Microsoft WebMatrix goto Menu Files->Options->Site Enter in Default Site location the parent directory of "Umbraco CMS" In case the CMS is running - stop it Then close WebMatrix With Windows Explorer move or copy the directory from the Users Directory into the desired target directory.
    Launch WebMatrix Click on Open Select the "Umbraco CMS" paste directory. If you did it correctly, it launches from the new location.
    Jan 23, 2017 @ 23:04
    Alex Skrypnyk
    Hi Matjung
    Try to use Visual Studio and install Umbraco via nuget - this is perfect way to install umbraco on local machine.
    Read more: https://our.umbraco.org/documentation/getting-started/setup/install/install-umbraco-with-nuget
    Hope it will help.
    Alex
    Jan 29, 2017 @ 21:41
    Alex Skrypnyk
    Hi Matjung
    Can you share with community what did you do?
    Did you solve the problem?
    thanks
