I have a content node which has a field of the data type - "Umbraco.Tags" which is throwing the following error in the console - "Error: Duplicates in a repeater are not allowed. Repeater: tag in model.value key: string:salt".
Is there anyone who encountered such issue? How have you tackled it? I already have done some research but there is not lots of info on such subject and I honestly can't figure it out.
Basically the issue is that in some way the user manages to input a word twice (for example in my case the word - 'salt') and save. Apparently this is not allowed and that error is thrown.
My solution was to reset the field manually from the database by running the below query:
UPDATE [INSERT DB NAME HERE].[dbo].[cmsPropertyData]
SET dataNtext='', dataNvarchar=''
WHERE contentNodeId=INSERT CONTENT ID HERE AND propertytypeid=INSERT TAG DATA TYPE ID HERE;
And then warning the person who inputs content to make sure that he does not accidently input words twice.
But I am thinking to switching to just a text area and storing a CSV into it. Since this is not flexible as I hoped and causing more issues than it should!
Umbraco Tags Data Type throwing "Duplicates in a repeater are not allowed"
Anyone that can be of help please? Thanks
Hi Fabian, were you able to figure this out? Getting the same issue over here.
-Amir
Hi Amir,
UPDATE [INSERT DB NAME HERE].[dbo].[cmsPropertyData] SET dataNtext='', dataNvarchar='' WHERE contentNodeId=INSERT CONTENT ID HERE AND propertytypeid=INSERT TAG DATA TYPE ID HERE;
We have the same problem, is there some fix?
Only via the database?
Alex
I had the same issue
Temporary fix via DB works well, I see an issue has been raised in the bug tracker. No sign of a fix yet.
