What I want to do is to upgrade an umbraco 6.2.x to 7.1.x, using an intermediary 7.0.4 version.
For the moment I only tried the procedure on a very simple project : a basic umbraco 6.2.6 (installed with NuGet) with a simple doc type and a page (hello world).... but after 3 attempts, it never worked.
I don't understand what i missed. PLEASE help me, I'm kind of desperate now :/. So from my VS2015 project I followed the manual procedure, here is what I did :
I downloaded the umbraco 7.0.4 zip
Copied the bin, Umbraco, Umbraco_Client folders over my installation.
But why copy "over" ? Is it not safer to delete and paste the new folders ? (tried both)
Merged files (config, global.asax...)
On my basic project is more like "replace" than merge. I see no reason to keep any v6 value instead of v7. So i only kept the connectionString and the
<add key="umbracoConfigurationStatus" value="6.2.6"/> line in the web.config.
Did I miss something ?
So at this time, when opening the website I was suppose to get an update screen ? And by "opening" your site, do you mean connect to the backoffice ?
What is supposed to trigger the display of the upgrade page ?
on"localhost" is my "hello world", as before
on "localhost/umbraco"
Unable to load the type 'Umbraco.Web.UI.Umbraco.umbraco'.
I don't think it was a files persmissions problem, but I will check that.
I tried to update umbraco using NuGet and it worked properly, I can see the upgrade screen. But only because I set the umbracoConfigurationStatus value to an empty string instead of keeping the previous version number. It is not clear in the doc.
Upgrade v6 to v7 impossible - Right way ?
Hi everyone,
Before anything, I assure you I have followed carefully the general and specific upgrade documentation : https://our.umbraco.org/documentation/Getting-Started/Setup/Upgrading/upgrading-to-v7 https://our.umbraco.org/documentation/getting-started/setup/upgrading/general
What I want to do is to upgrade an umbraco 6.2.x to 7.1.x, using an intermediary 7.0.4 version. For the moment I only tried the procedure on a very simple project : a basic umbraco 6.2.6 (installed with NuGet) with a simple doc type and a page (hello world).... but after 3 attempts, it never worked.
Copied the bin, Umbraco, Umbraco_Client folders over my installation. But why copy "over" ? Is it not safer to delete and paste the new folders ? (tried both)
Merged files (config, global.asax...) On my basic project is more like "replace" than merge. I see no reason to keep any v6 value instead of v7. So i only kept the connectionString and the
<add key="umbracoConfigurationStatus" value="6.2.6"/>line in the web.config.Did I miss something ?
So at this time, when opening the website I was suppose to get an update screen ? And by "opening" your site, do you mean connect to the backoffice ? What is supposed to trigger the display of the upgrade page ?
<%@ Page Language="C#" AutoEventWireup="true" CodeBehind="umbraco.aspx.cs" Inherits="Umbraco.Web.UI.Umbraco.umbraco" %>
And nothing alarming in logs :
Thank you for your help, it is very important to me :).
Hi Julien
Can you check folders permissions?
Upgrade page should be when you go just to front page.
Alex
Why? Why not go straight to the latest verion which has hundreds of bug fixes and improvements?
Attempting to visit any page in the site will send you to the upgrade installer.
Maybe this? http://stackoverflow.com/a/25461860/5018
I've written a blog post listing ways to debug upgrade problems:
https://cultiv.nl/blog/how-to-diagnose-umbraco-upgrade-problems/
Thank you for your support :).
I can't upgrade above 7.1.x because some of the package I use won't be compatible in a more recent version. Like : https://our.umbraco.org/projects/website-utilities/multi-language-tools/ So it would be a lot of work to change.
Now I have all the SQL upgrade errors described here : https://www.sorendam.com/upgrade-umbraco-4-11-7-database-to-umbraco-7-0-4/ Disappointing :).
I will try the direct update to 7.1.x, maybe it is easier. My idea of using an intermediary 7.0.4 might be worse.
Thanks again, but is not a success yet :)
Great news, I sucessfully migrated my "hello world 6.x" umbraco directly to the 7.1.9 version.
So clearly the 7.0.4 seems to be a not-so-good-to-upgrade version.
