[MembershipHelper] [ProfileModel] - MembersProperties does not return any custom properties
var member = Members.GetCurrentMemberProfileModel();
var customProperties= member.MemberProperties; // count always 0
I don't understand why the member properties does not return any custom properties.
The MembershipHelper documentation states "When looking at the currently logged in Member, you will get a ProfileModel back, which contains the same data, by with additional methods and properties available which are specific to members."
I am using a custom Member Document Type. I am on Umbraco v7.5.8
Have you ticked the box to enable the custom property to be added to the Profile Model ?
I only ask because the position of this tick box has moved in Umbraco 7.5.x and is not quite so obvious.
and also there is a long standing bug where you have to tick 'Show on profile' AND 'Member can edit' for the properties to appear in the ProfileModel !!!
Previously it was here:
and now it's moved to each individual property setting, which is much better place for it, but the docs are a little behind to explain where it's moved to:
I've just tried this and confirm the bug is still there - you still need to tick both boxes for the property to be included in the ProfileModel!!
Hi Ronish
regards
Marc
