  • Owain Williams 482 posts 1414 karma points MVP 8x c-trib
    Feb 01, 2017 @ 14:29
    Owain Williams
    Document Type help.
    Hi This is more a 'can it be done' sort of question than 'how do I do it'. I want to learn but at the same time I can't think how I could achieve what I'm looking to do.
    I want to have a navigation bar which I can create unlimited number of links from or should I say, allow an editor to create.
    I'm thinking a text box called 'navigationText' and another text box called 'navigationURL'. The editor would enter in the text e.g. Contact Us and the url could be 'http://something.com/something'
    They could then click a button to 'add more links' and each time they do this, the navigation would increase.
    This might sound like a strange thing to be doing but I'll try and explain why. The main website will be hosted on a separate system so I need to be able to hardcode the links or give the editor this option.
    Can this be done with Document Types or should I be looking somewhere else?
    Not sure if I have explained myself very well but if you have any questions, please ask :)
  • Ronish Potiah 19 posts 171 karma points
    Feb 01, 2017 @ 14:36
    Ronish Potiah
    Hi Owain,
    You can use the umbraco native related-links to get going.
    Here is how you can use it related-links
    On your document type, click to add property and choose related links data type.
    Feb 01, 2017 @ 14:41
    Owain Williams
    Thanks for the quick reply. This looks perfect!
  • Dennis Adolfi 1082 posts 6450 karma points MVP 7x c-trib
    Feb 01, 2017 @ 14:43
    Dennis Adolfi
    Hi Owain.
    This could very much be a doctype solution, it sounds like you have a good plan. May I suggest however that you have a look at Nested Content? It's pretty much the same setup as you where mentioning, however instead of having a singe child for every menu-option, they would all be listed on the 'Home' node for example. Have a look at Nested Content: https://our.umbraco.org/projects/backoffice-extensions/nested-content/ (Or you could consider to list the menu items in a List-View, depending on your structure.)
    However a much simpler and in my opinion cleaner way of doing this is using a package called RJP.MultiUrlPicker property. It's pretty much exactly what you need: You can select an internal/external link, a title and a text, and that's it! No need for menu item doctypes. I use this package for 90% of all my project menus: https://our.umbraco.org/projects/backoffice-extensions/multi-url-picker/
    Best of luck!
    Feb 01, 2017 @ 14:56
    Owain Williams
    Thanks Dennis, I was going to look at packages but because I'm trying to learn how to use Umbraco from a dev point of view I thought I'd try and stay clear of packages just now. Yes, it might add time to my project but the knowledge I will hopefully gain will be worth it.
    I will look at the package though for future reference. I'll also look at nested content.
    Thanks.
