  • Siavash Mortazavi 24 posts 145 karma points
    Feb 07, 2017 @ 15:06
    Siavash Mortazavi
    What are top audit and performance testing tools for Umbraco 4?
    I've inherited an Umbraco 4.x (I don't know the minor version yet) website for audit and enhancement.
    Beside the general performance measurement tools, such as YSlow or WebDevChecklist, is there a good performance measurement tool that I can use on my Umbraco 4 website to find the issues?
    Thanks, Sia.
    Feb 07, 2017 @ 16:54
    Alex Skrypnyk
    Hi Siavash
    If you want to use some remote tools, try https://gtmetrix.com and https://developers.google.com/speed/pagespeed/insights/
    To audit performance on the server try to use MiniProfiler, what is the part of the core also MSSQL profiler.
    I hope it will help you.
    Alex
    Feb 08, 2017 @ 03:31
    Siavash Mortazavi
    Hi Alex,
    Thanks for your reply. Actually except MiniProfiler, I've had worked with other tools.
    So, is there an Umbraco-specific tool that can check the health of an Umbraco 4 website? I know in Umbraco 7 I can go to Developers section > "Health Check" tab to perform some tests.
    Thanks again, Sia
    Feb 08, 2017 @ 11:52
    Alex Skrypnyk
    Hi Sia
    "Health Check" was introduced in 7.5 version.
    So I think there are no such packages for version 4.
    For 7 version you can try God Mode package also - https://our.umbraco.org/projects/developer-tools/diplo-god-mode/
    Alex
    Feb 09, 2017 @ 14:09
    Siavash Mortazavi
    Thank you, Alex! :-)
