  • blackhawk 313 posts 1368 karma points
    Feb 20, 2017 @ 15:01
    blackhawk
    Understanding the difference between an Umbraco Package and Project
    I'm seeing a lot of cross terms on the forum about Umbraco Packages and Projects. I'm finding both terms being used on various pages (i.e. this one for example). What is the main difference between both terms when it comes to Umbraco 7+ technology.
    And if they mean the same thing, why do we need 2 terms?
    Feb 20, 2017 @ 15:08
    Alex Skrypnyk
    Hi Kensley
    Projects section at this site https://our.umbraco.org/projects/ is a list of projects which work in combination with Umbraco or have some relation to Umbraco, but it's not 100% package.
    Package for Umbraco it's a special type of packing project. You can install any Umbraco package via Packages menu item in the Umbraco in Developers section. So Package it's packed project. Read this article - http://www.markwemekamp.com/blog/umbraco/publishing-your-first-umbraco-package/
    Alex
    Feb 23, 2017 @ 11:43
    Alex Skrypnyk
    Hi Kensley
    Did you understand what is the difference? Maybe you can share your ideas?
    Alex
    Feb 26, 2017 @ 02:33
    blackhawk
    So packages are umbraco-based plugins while projects may be more extendable than that?
    Feb 26, 2017 @ 22:57
    Alex Skrypnyk
    Yes, Kensley
    Feb 28, 2017 @ 13:42
    Alex Skrypnyk
    Is it make sense?
    Was it interesting info for you?
    Feb 28, 2017 @ 14:19
    blackhawk
    It makes perfect sense. Thank you so much for the help Alex.
