  • Terry Clancy 204 posts 944 karma points
    Feb 24, 2017 @ 18:19
    Terry Clancy
    uCommerce breaks with Umbraco upgrade
    Hi all,
    I just upgraded Umbraco from 7.4.1 to 7.5.10 using the Visual Studio Nuget command Update-Package UmbracoCms After the upgrade several files were missing from the path /Umbraco/uCommerce and so I copied that whole folder across from a prior installation. The site then ran but when I go into Umbraco Back Office I found the following two problems (1) The uCommerce icon in the left hand margin is missing. (2) When I go to Developer / Packages the only item in that menu is “Created Packages” there is no option to install a local package. (I was going to upgrade uCommerce) Note that I tried this whole process twice. Once running the site after upgrade using Visual Studio / IISExpress and one using IIS. Can anyone suggest what might be going wrong and how to overcome the problem ?
    Terry Clancy ClanceZ
  • Søren Spelling Lund 1797 posts 2786 karma points
    Feb 27, 2017 @ 10:21
    Søren Spelling Lund
    Hi Terry,
    Could you crosspost your question to Eureka where the uCommerce support team hangs out? The team will pick up your question and do a repro.
    If you could include version info about uCommerce as well as Umbraco that would be super helpful to ensure speedly turnaround on the solution.
    Thanks.
    Feb 28, 2017 @ 05:44
    Terry Clancy
    Thanks very much. All done and already answered by the wonderful Mads :-)
    See http://eureka.ucommerce.net/#!/question/2141/uCommerce-breaks-with-Umbraco-upgrade#top
