  • Peter W 1 post 71 karma points
    Mar 02, 2017 @ 14:41
    Peter W
    Umbraco maintenance
    Does somebody know if there is documentation available on how to maintain an umbraco installation? like best practices, what to check etc.
    Thanks Peter
    Mar 02, 2017 @ 14:51
    Alex Skrypnyk
    Hi Peter
    What version of Umbraco are you using? If you are using Umbraco Cloud - you have to do almost nothing. Look at Umbraco Cloud benefits - https://umbraco.com/products/umbraco-cloud/
    You have to add your email to /Config/UmbracoSettings.config notifications section and check log regularly. You can find log files in /App_Data/Logs/ folder or install Diplo Trace Log Viewer and use it for checking the log entries.
    Alex
