I want to change my admin password, then click Edit button. Suddenly, It redirects to login page. It says "Session timed out. Log in below". Why can this happen?
** I try to delete everything underneath of App_Data\TEMP...
maybe it could be a solution. But, still continue.
I found error. I changed section permission (add deny for root) on Dashboard.config, 2 days ago. Then, I take back old Dashboard.config. It was fix. Thanks again.
umbraco change password - session problem
Hi All,
** I try to delete everything underneath of App_Data\TEMP... maybe it could be a solution. But, still continue.
Regards.
I'm guessing that change password clears your logged-in status. I'm not sure why this is an issue though. Do you change your password a lot?
