  • Manish 373 posts 932 karma points
    Mar 07, 2017 @ 13:44
    Manish
    Drop down values in razor
    I have a dropdownlist with pre values in CMS. I want to get all items on a razor page.
  • Ravi Motha 290 posts 500 karma points MVP 9x c-trib
    Mar 07, 2017 @ 14:35
    Ravi Motha
    Do yuo want to populate the drop down or or are you just trying to display a dropdownyou have set up in the back office??
    Mar 08, 2017 @ 05:14
    Manish
    Ravi thanks for your attention on problem
    I just wanted to show all values which is in CMS for drop down. I wanted to render all on my razor page.
    Manish
  • Dharmesh 50 posts 210 karma points
    Mar 08, 2017 @ 05:22
    Dharmesh
    Hi Manish,
    You can do that in razor using this code:
    @{ var dataTypeId = umbraco.cms.businesslogic.datatype.DataTypeDefinition.GetAll().First(d => d.Text == "Dropdown").Id; var preValues = umbraco.cms.businesslogic.datatype.PreValues.GetPreValues(dataTypeId).Values; var enumerator = preValues.GetEnumerator();
    while (enumerator.MoveNext())
        var preValueText = ((umbraco.cms.businesslogic.datatype.PreValue)enumerator.Current).Value;
        <option>@preValueText</option>
    Mar 08, 2017 @ 08:47
    Manish
    Thank you. Let me try with above one.
    Mar 08, 2017 @ 09:09
    Manish
    Thanks dharmesh it is working except one thing it is showing "Pre values is obsolate" as warning.
    Mar 08, 2017 @ 09:26
    Ravi Motha
    Hi Manish,
    I am preuming you are working in version 7.x so you may want to take the following approach to get those values
    This question and and answer should help you get what you want https://our.umbraco.org/forum/extending-umbraco-and-using-the-api/78280-get-pre-values-for-data-type
    Ravi
    Mar 08, 2017 @ 09:33
    Manish
    Yes I am using umbraco 7.x
