I have created a RTE stylesheet and attached it to a RTE data type via the developer section.
I have added a few styles, i.e.
Header h4 font-size:200%
red .red color:#FF0000;
from the format dropdown menus both are available and can be applied to the content within the RTE. In the back office i can see the styles applied to the content. When viewing on the front end, no styles from the RTE style sheet are applied ?
RTE styles class not working
Dear Umbraco Team
Is there somthing im missing ?
thanks Dibs
Hi Dibs,
If I understand your problem correctly:
The stylesheet needs to be attached to the rendering of the content as weel, or at least be reflected in the stylesheet on the rendered page.
An example is, if you use Sass or Less to import the RTE style into the render style.
I hope this answers your question :)
Hi Vidar
thanks for you input, as i was reading your resposne i realised i hadn't referenced the RTE style sheet in my master paeg.
my fault : (
Thanks Dibs
