  • Chris Erickson 1 post 71 karma points
    Mar 08, 2017 @ 17:31
    Chris Erickson
    Problems adding external css and js files
    Hello all,
    Very new to Umbraco and not really sure what I am doing wrong. Using the default starter kit (fanoe) I am trying to add the following to the Master Template:
      <link rel="stylesheet" type="text/css" href="/css/kendo.common.min.css" />
      <link rel="stylesheet" type="text/css" href="/css/kendo.default.min.css" />
    However, when I test the site I am getting 404s saying:
    HTTP404: NOT FOUND - The server has not found anything matching the requested URI (Uniform Resource Identifier).(XHR)GET - http://localhost:52990/source/web/kendo.common.css
    HTTP404: NOT FOUND - The server has not found anything matching the requested URI (Uniform Resource Identifier).(XHR)GET - http://localhost:52990/source/web/kendo.default.css
    I am also getting a script undefined error but I think if I can figure out how/where to put files or what is happening with the paths everything will sort itself out.
    Oddly I am seeing the files in backoffice.
    Any help would be appreciated.
    Thanks, Chris
  • Nigel Wilson 945 posts 2077 karma points
    Mar 12, 2017 @ 22:41
    Nigel Wilson
    Hi Chris
    Firstly the link tags show ".min.css" files, but the 404's show the non minified css file. Is this part of the issue ?
    Also the localhost URL looks plain weird - typically it should be http://localhost:52990/css/mycssfile.css
    In terms of your Visual Studio solution have you got the start website and directory set correctly within the project ?
    Cheers, Nigel
