  • Dibs 202 posts 991 karma points
    Mar 14, 2017 @ 23:21
    Dibs
    Render related links within Archetype Data type
    Dear Umbraco Team
    I have created a Archetype Data Type with a related links property editor. How can i render the link ? i.e
    <a href="value of related link within Archetype DataType">click here</a>
    Thanks Dibs
    Mar 15, 2017 @ 00:28
    Alex Skrypnyk
    Hi Dibs
    It's really nice way to get RelatedLinks data from Archetype property if you install "Umbraco Core Property Value Converters" also - https://our.umbraco.org/projects/developer-tools/umbraco-core-property-value-converters
    With this package you will be able to get data with this code: Umbraco Core Property Value Converters
    @foreach (var fieldset in Model.GetPropertyValue<ArchetypeModel>("archetypeField"))
        fieldset.GetValue<RelatedLinks>("relatedcontentlinks");
    Alex
    Mar 15, 2017 @ 08:48
    Dibs
    Cheers Alex
    I will give the package a go, but is their way to do it without the package ?
    Thanks Dibs
    Mar 15, 2017 @ 09:10
    Alex Skrypnyk
    Hi Dibs,
    Yes, you can do it without package, Related Links stores data in JSON.
    Use this code:
    @using Newtonsoft.Json.Linq
    @foreach (var fieldset in Model.GetPropertyValue<ArchetypeModel>("YOURarchetypeField"))
        foreach (var item in fieldset.GetValue<JArray>("YOURrelatedcontentlinksField"))
            var linkUrl = (item.Value<bool>("isInternal")) ? Umbraco.NiceUrl(item.Value<int>("internal")) : item.Value<string>("link");
            var linkTarget = item.Value<bool>("newWindow") ? "_blank" : null;
            <a href="@linkUrl" target="@linkTarget">@(item.Value<string>("caption"))</a>
    As you see "Umbraco Core Property Value Converters" gives you much readable code, but of course it's one more package and maybe no sense if you use only one class. Hope it will solve your issue.
    Alex
    Mar 15, 2017 @ 10:11
    Alex Skrypnyk
    fieldset.GetValue
    Mar 15, 2017 @ 10:15
    Dibs
    Cheers Alex
    I did see that code on the our umbraco documentation but wasn't sure how to use it.
    I typed it in and hoped for the best : )
    It works
    Thanks Dibs
    Mar 15, 2017 @ 10:17
    Alex Skrypnyk
    Cheers Dibs
    Glad that it works, have a nice day!
    /Alex
