  • Kent 4 posts 84 karma points
    Mar 20, 2017 @ 20:17
    Kent
    Umbraco Starts without Logging a Shutdown
    Running Umbraco 7.5.9 on Azure App Services, have encountered an issue where in the Umbraco logs Umbraco starts without logging a Shutdown or any issue.
    2017-03-20 19:03:28,832 [P2884/D2/T25] WARN  Umbraco.Web.UmbracoModule - Status code is 404 yet TrySkipIisCustomErrors is false - IIS will take over.
    2017-03-20 19:09:09,734 [P9768/D2/T1] INFO  Umbraco.Core.CoreBootManager - Umbraco 7.5.9 application starting on
    It appears as though the process changes and that it would be an issue with the w3wp process and IIS. Has anyone run into similar issues? I should add this is a production instance so logging is at a minimum.
