  • Maciej Rakowski 11 posts 91 karma points
    Mar 25, 2017 @ 11:26
    Maciej Rakowski
    Autofac not working
    I'm trying to setup Autofac for Umbraco and I'm failing hard. It looks like Autofac is ignoring the configuration.
    My Repository is always ending up as null. What am I missing?
    Here's the Startup config
    namespace MyApp.Website.EventHandlers
    public class ApplicationStartedEventHandler : IApplicationEventHandler
        public void OnApplicationInitialized(UmbracoApplicationBase umbracoApplication, ApplicationContext applicationContext)
        public void OnApplicationStarting(UmbracoApplicationBase umbracoApplication, ApplicationContext applicationContext)
        public void OnApplicationStarted(UmbracoApplicationBase umbracoApplication, ApplicationContext applicationContext)
            RegisterAutoMapper.PopulateAutoMapper();
            var builder = new ContainerBuilder();
            builder.RegisterControllers(Assembly.GetExecutingAssembly());
            builder.RegisterApiControllers(typeof(UmbracoApplication).Assembly);
            builder.RegisterControllers(typeof(InstructorProfileStep2Controller).Assembly);
            builder.RegisterControllers(typeof(RegisterController).Assembly);
            builder.RegisterControllers(typeof(Umbraco.Forms.Web.Trees.DataSourceTreeController).Assembly);
            builder.RegisterType<InstructorRepository>().As<IInstructorRepository>().InstancePerLifetimeScope().PropertiesAutowired();
            var container = builder.Build();
            var resolver = new AutofacWebApiDependencyResolver(container);
            GlobalConfiguration.Configuration.DependencyResolver = resolver;
            DependencyResolver.SetResolver(new AutofacDependencyResolver(container));
    Now the builder.RegisterControllers(typeof(InstructorProfileStep2Controller).Assembly); builder.RegisterControllers(typeof(RegisterController).Assembly); should register my controllers - one is RenderMvcController another one is SurfaceController.
    The implementation of Repository is as follows:
        namespace MyApp.DataAccess
        public class InstructorRepository : IInstructorRepository
            public InstructorProfileDto GetInstructorProfile(int id)
                return null;
    And inside Controller - Repository here is always null:
    public class InstructorProfileStep2Controller: RenderMvcController
        public IInstructorRepository InstructorRepository { get; set; }
        public override ActionResult Index(RenderModel model)
            InstructorProfileStep2Model viewModel = new InstructorProfileStep2Model(model.Content);
            InstructorRepository.GetInstructorProfile(1123);
            return base.Index(viewModel);
    And project structure
  • Yakov Lebski 594 posts 2350 karma points
    Mar 25, 2017 @ 13:36
    Yakov Lebski
    I think better way is to use constructor initialization like
     public void InstructorProfileStep2Controller(IInstructorRepository instructorRepository)
        _instructorRepository=instructorRepository
    For apply property auto-wired on controller you should enable it
    builder.RegisterControllers(Assembly.GetExecutingAssembly()).PropertiesAutowired();
    Mar 25, 2017 @ 13:47
    Maciej Rakowski
    Hi Yakov
    That works. Although it's not the perfect solution for us. We would prefer to go with Repository being a autoinjected property. Having in mind the above solution works, do you have any ideas why the solution provided by me isnt't working?
    Mar 25, 2017 @ 13:54
    Yakov Lebski
    Did you try this one ?
    Mar 25, 2017 @ 14:05
    Maciej Rakowski
    Thanks!
    That worked. The only thing I had to either remove my
    or apply PropertiesAutowired() on them.
    Maciej
    Mar 25, 2017 @ 14:10
    Yakov Lebski
    I think you can register all controllers in one row
    or define per each controller
    builder.RegisterControllers(typeof(InstructorProfileStep2Controller).Assembly).PropertiesAutowired();
    builder.RegisterControllers(typeof(RegisterController).Assembly).PropertiesAutowired();
