  • Oliver Cross 1 post 71 karma points
    Apr 08, 2017 @ 17:02
    Oliver Cross
    Issue With Importing Document Types in Umbraco 7.5
    I am trying to import a document type into a 7.5.11 Umbraco installation currently hosted on the Microsoft Azure Web app platform.
    On importing the document type I am immediately greeted with the following Exception error enter image description here
    Initially I was running Umbraco 7.3 default from the template directory in Microsoft Azure. and had the same error. I have upgraded in the hope that it may fix it but to no avail.
    I am new to Umbraco so I'm not too sure where to start troubleshooting this. THere is nothing in the log table that indicates any kind of issue either.
    thanks for any help in advance.
  • Paul Wright (suedeapple) 277 posts 704 karma points
    Apr 09, 2017 @ 12:47
    Is the documenttype using a non-core property editor for one of its fields?
    You may need to install that first.
