A few months ago I installed v2 of David Brendel's awesome event calendar plugin. I've was using the v2.x version successfully but the client asked for the ability to do annual renewals such as birthdays and anniversaries as well so I installed v3 last night and ran into a few issues...
Initially I got an error about trying to enter a route value that already existed into the routes collection, I assume this was because I did not uninstall v2 first. So I had to uninstall v2, then reinstall v3, and it seemed to work ok.
Now however when I open the EventCalendar tab from the left nav bar, I get an error that says "Error: Could not load calendar" and I have no calendars or locations folder like I expect.
Any ideas? At this point I have no code that I can share because this is just an out of the box install.
So even though NuGet showed that I had NewtonSoft 7.01, the actual file version in the bin was v6 and the web.config was still showing v6. So I updated the project to use 7.01 and the "Could not load calendar" error did disappear. :-)
Now I just have one issue which is that there is nothing in the left side (div id="navigation"). It is collapsed just as is the screenshot above. When I go poking around with developer tools it is actually display:none, and even when I force it to show, it's is empty.
Ok, in all of my moving files around I somehow left out the licensing dll. I added that back to the bin and now there are no console errors and no on screen errors, but still no left navigation area.
We are making progress but not quite there. Thanks for sticking with me.
Looks like I am good to go. I haven't tried creating anything yet, but it looks like I am ready to get started now. Thanks again for your assistance & patience. You should see the licence purchase tonight.
EventCalendar 3.2.2 "Error: Could not load calendar"
Hello everyone,
Thanks -Roger
Hi Roger,
sorry for the delay.
First thing would be to check if you updated newtonsoft.json to version 7.0.1.
This is needed as the Google calendar c# library depends on it.
If that is not the cause we have to check further.
Regards David
I am getting some console errors.
Does this help or is there any more info I can provide?
Thanks so much for your help!
Hi Roger,
seems that some of the config files were not correctly manipulated during install.
Can you check if you have that entry in the trees.config file:
The custom section itself is showing correct?
Regards David
I see the section now!! It was in there, but this must have been the old one, so yeah it seems something went screwy in the install.
