Really strange issue I hope someone can provide suggestions on.
This is the scenario
I create an Umbraco site (V 7.5.13) using Visual Studio and Nuget with a SQL database - this is on my local machine and is running under a "localhost" URL.
I install the TXT starter kit as part of the installation process
I go to Developer and locate the Merchello package
The information screen appears and I can click the Install Package button.
The screen then simply refreshes back to the package listing.
The above I have done at work and have experienced no problems.
I have tried both Chrome and Firefox with the same behaviour.
There are no error logs and nothing in the developer console to indicate a problem.
Has anyone else experienced this, or can offer suggestions ?
I was just struggling with this issue as well and it was driving me nuts until I found out that I had the "Browser Reload" extension enabled in Visual Studio which was causing this problem. Disabling the extension solved the problem for me.
Installing Package Issue
hi there
Nigel
Further to previous post, I have now tried running my test site via http://merchello.local instead of via debug mode in Visual Studio.
The Merchello package install worked fine this way.
This weirdness did not occur at work and am stumped as to why / what is causing the problem.
Be interested to hear if anyone else has experienced this behaviour and if they figured out a solution.
Cheers, Nigel
