  • Elvis 4 posts 76 karma points
    Apr 24, 2017 @ 10:11
    Elvis
    Templates do not render using cloud or IIS
    Hi, I have started and deployed a blank umbraco starter website. I can run and edit the website on local .net express service, however, when I run it from IIS or a deployed version of umbraco, I can edit the website and use umbraco management pages, but the website will not render my templates giving me an error message "No physical template file was found for template Home".
    What do I need to do to fix that? I checked the forums, and normally the issue is caused my custom controls. But all my controls are out-of-the-box umbraco starter kit.
    Many thanks,
    Elvis
    Apr 24, 2017 @ 16:18
    Alex Skrypnyk
    Hi Elvis
    Can you check, please, folders permissions?
    It should be like here - https://our.umbraco.org/documentation/getting-started/setup/install/permissions
    Alex
    Apr 25, 2017 @ 16:44
    Elvis
    I checked with the admin. I have "Full access" folder permissions for my site. This is the error that I am getting: http://skensberg.gear.host If you can think of any other solutions I'd appreciate it.
    Elvis :)
    Apr 25, 2017 @ 16:46
    Alex Skrypnyk
    101
    Can you edit templates if you go to Umbraco backend -> Settings -> Templates?
    Alex
    Apr 26, 2017 @ 08:49
    Elvis
    Alex, you've hit the nail on the head! Yeah, templates were missing. I don't know why but the blank umbraco template had its files in View Folder removed from project by default. Just had to click View hidden files and include them in the project. Thanks so much! :)
    Apr 26, 2017 @ 09:00
    Alex Skrypnyk
    You are welcome, Elvis, glad to help.
    /Alex
    Apr 25, 2017 @ 10:10
    Elvis
