I just get the latest sources of Umbraco and trying to run it from source code. But have troubles doing it.
Is it some kind of special configuration of setup I need on my machine?
Based on logs it looks like a lot of files not found in /Umbraco/Js folder, in my case I have 12 files, but compiled version have 29 files
I was also trying to build using /build/build.bat but it gives me MSBuild error
d:\Downloads\Umbraco-CMS-dev-v7\src\umbraco.presentation.targets(68,38): error MSB4022: The result "" of evaluating the
value "$(WebPublishingTasks)" of the "AssemblyFile" attribute in element
I assume it needs visual studio 2015, but on my machine, I have only visual studio 2017 installed.
At least point me in right direction, maybe some guide or document...
Running Umbraco from source code in VS2017
Hello, I just get the latest sources of Umbraco and trying to run it from source code. But have troubles doing it. Is it some kind of special configuration of setup I need on my machine?
The issue I have: redirect to this page http://localhost:7513/install/?redir=true&url=http%3a%2f%2flocalhost%3a7513%2f and an error message "A server error occurred This is most likely due to an error during application startup"
d:\Downloads\Umbraco-CMS-dev-v7\src\umbraco.presentation.targets(68,38): error MSB4022: The result "" of evaluating the value "$(WebPublishingTasks)" of the "AssemblyFile" attribute in element
add this to your umbraco.presentation.targets file:
