I have two compositions compo1 and compo2. both with a tab called "content". Each have several properties. compo1 has sortorder 1 and compo2 has sortorder 2.
I have a document type that inherits both compositions and I can only see one tab as expected. However all properties are mixed up.
Is it possible to have properties from compo1 listed first and so forth, so properties sort order follow their parent/tabs sort order?
Sorting works fine for the tabs.
Problem/bug is when tabs have the same name and properties are shared i one tab. The properties are not sorted in any way.
Lets say that compo1 have property1, property2, property3 in at tab called "Content" and Combo2 have property4, property5, property6 in a tab also called "Content"
On my document type DTXXX i have inherited compo1 and compo2 I will have one tab called "Content" but the properties are listed:
property1
property4
property2
property5
property3
property6
I would like to have them listed for combo1 first and then combo2
property1
property2
property3
property4
property5
property6
Thanks Dave,
Marc that is a nice solution. Any idea when this will be released in a official release? or is this some of thoose that Niels i talking about that takes major changes in the core?
I think it's something that needs a bit of a chat with the core team, it's a common recurring problem people hit, and so it should have some discussion eg whether to put a strip of plaster over the problem to help people now, or whether to think why are they hitting that problem in the first place :-)
The core team are locked down into delivering 7.6, Forms and Deploy, so won't get much headspace until post codegarden I suspect.
Compositions properties sort order
I have two compositions compo1 and compo2. both with a tab called "content". Each have several properties. compo1 has sortorder 1 and compo2 has sortorder 2. I have a document type that inherits both compositions and I can only see one tab as expected. However all properties are mixed up.
Thanks in advance
Rasmus
Try -1 for compo1 and 0 for compo2
Sorting works fine for the tabs. Problem/bug is when tabs have the same name and properties are shared i one tab. The properties are not sorted in any way. Lets say that compo1 have property1, property2, property3 in at tab called "Content" and Combo2 have property4, property5, property6 in a tab also called "Content" On my document type DTXXX i have inherited compo1 and compo2 I will have one tab called "Content" but the properties are listed: property1 property4 property2 property5 property3 property6
I would like to have them listed for combo1 first and then combo2 property1 property2 property3 property4 property5 property6
Does that make sense?
A fix could be:
in file: Umbraco\Views\components\umb-groups-builder.html line 110 change:
to:
Of course it would be better if the model had "contentSortOrder" instead of "contentTypeName" to order by.
And similar changes in file: Umbraco\Views\content\edit.html
created an issue with the above solution here: issues.umbraco.org
Hi Rasmus,
As a work around Marc Goodson provided some suggestions in this topic :
https://our.umbraco.org/forum/using-umbraco-and-getting-started/84657-order-properties-from-multiple-compositions
Dave
There is an ongoing issue regarding this too here:
http://issues.umbraco.org/issue/U4-6738
with another 'partial fix' :-)
Thanks Dave, Marc that is a nice solution. Any idea when this will be released in a official release? or is this some of thoose that Niels i talking about that takes major changes in the core?
Fingers crossed
