I think what you have written is correct, but I've added the ´ sign just to sure that you are removing the right symbol.
However, when you add a new urlReplacing rule, all your existing URL:s will not automagically update, that would be super scary. Instead, you need to Save & Publish for your new Url to be generated.
So I added this to my umbraco.config file, under the requestHandler section:
Umbraco url Apostrophe problem
Hi All I am using umbraco 7.5 Name of my page is some like that
About John's
and Umbraco CMS generate Url like this
But I wanted url something like that
I have tried setting in umbraco config file something like that
But this is not working. Someone please help me out
Also try by adding this in web.config file
But it added .aspx at end.
Hi Manish.
´sign just to sure that you are removing the right symbol.However, when you add a new urlReplacing rule, all your existing URL:s will not automagically update, that would be super scary. Instead, you need to Save & Publish for your new Url to be generated.
requestHandlersection:And i got this url:
See animation:
NOTE: I'm also using Umbraco 7.5
Best of luck to you Manish. Let me know how it goes or if you need anymore help.
Take care / Dennis
Yeah actually the problem was symbol
using this working fine now
Thanks Dennis
Glad it worked out for you Manish! Happy to help!
Have a great weekend!
