Hey :)
I've been trying to make a navigation menu for the first time.
I've most of it working, but can't figure out how to make the frontpage get the "current" class when that page is active.
Here is what i've for now:
@inherits Umbraco.Web.Macros.PartialViewMacroPage @{ var selection = CurrentPage.Site().Children.Where("Visible"); } <ul> <li><a href="/">Home</a></li> @foreach (var item in selection) { <li class="@(item.IsAncestorOrSelf(CurrentPage) ? "current" : null)"> <a href="@item.Url">@item.Name</a> @if (item.Children.Where("Visible").Count() > 0) { <ul class="dropdown"> @foreach (var subpage in item.Children.Where("Visible")) { <li><a href="@subpage.Url">@subpage.Name</a></li> } </ul> } </li> } </ul>
Thanks in advance :)
Hi Mikkel,
What do you mean with front page ? Your homepage ?
Dave
Hey Dave :)
Yes that's what i mean
This example should work. You only need to replace "HomePageDocTypeAlias" with the actual alias of your homepage doctype :
@inherits Umbraco.Web.Macros.PartialViewMacroPage @{ var selection = Model.Content.AncestorOrSelf(1).Children().Where(x => x.IsVisible()).ToList(); } <ul> <li class="@(Model.Content.DocumentTypeAlias == "HomePageDocTypeAlias" ? "current" : null)"><a href="/">Home</a></li> @foreach (var item in selection) { <li class="@(item.IsAncestorOrSelf(Model.Content) ? "current" : null)"> <a href="@item.Url">@item.Name</a> @{ var children = item.Children.Where(x => x.IsVisible()).ToList(); } @if (children.Any()) { <ul class="dropdown"> @foreach (var subpage in children) { <li><a href="@subpage.Url">@subpage.Name</a></li> } </ul> } </li> } </ul>
I also took the liberty to refactor it to use strongly typed content (Model.Content) access instead of the use of dynamics (CurrentPage)
To have a good understanding between the difference read this article I wrote : http://24days.in/umbraco-cms/2015/strongly-typed-vs-dynamic-content-access/
Hey again :D
Thank you! Works perfectly, going to dig into your article asap :)
if currentpage is frontpage add current class
Hey :)
Hi Mikkel,
Dave
Hey Dave :)
Hi Mikkel,
Dave
Hey again :D
