Hey all.
i have just installed the nuPicker package from the backoffice in an 7.5.6 umbraco installation.
i have created a sql dropdown picker, which works and gets and shows data in the dropdown from the database.
now i would like to get the data in a template. I have tried looking up some examples on how to do this and many of them have a reference to nuPicker like this @using nuPicker
when i try to add that reference i get this error:
The type or namespace name 'nuPicker' could not be found (are you missing a using directive or an assembly reference?)
@using nuPickers did it for me. now its working and i can get the Picker object. i did not add the namespace to the /views/web.config, but maybe ill have to add it at a later time if the reference is not working in all views.
anyway, thumbs up.
nuPicker using reference
Hey all. i have just installed the nuPicker package from the backoffice in an 7.5.6 umbraco installation.
now i would like to get the data in a template. I have tried looking up some examples on how to do this and many of them have a reference to nuPicker like this @using nuPicker when i try to add that reference i get this error: The type or namespace name 'nuPicker' could not be found (are you missing a using directive or an assembly reference?)
anyone why i cant reference nuPicker ?
I think it should be
@using nuPickers(plural)Easiest way to make this available to all views is to edit the web.config file in your /Views/ folder (not your main one) and then add in:
(Just add the above into namespaces and leave whatever is already there). This globally registers the namespace for all views.
thank you man!
@using nuPickers did it for me. now its working and i can get the Picker object. i did not add the namespace to the /views/web.config, but maybe ill have to add it at a later time if the reference is not working in all views. anyway, thumbs up.
