  • Barbacan 29 posts 79 karma points
    May 03, 2017 @ 12:32
    Barbacan
    Public Access authentication problem
    I've to protect my root site with custom login & password box, so I created a node with the two required pages, login and error and I've set Public Access on my home node as Role based protection:
    enter image description here Then I created the user which will be used for authentication:
    Finally I created the macro as an .ascx custom control. The code is very simple:
    The code works perfectly, it gets the user's credentials and do validation, but the redirect does not work and I stay on the login page. It seems that the auth cookie is not written. The web.config looks as follows: enter image description here
    I checked the file permission on the folders, the umbraco log, but apparently there are no issues. Any helps?
