Hi there.
Just found something odd.
When umbraco generates an URL, in my solution, with an å it becomes "aa", but capital Å becomes "å".
I'm running 7.5.13, anything I can do to change this?
like this:
nyheder/årets-naeststoerste-gevinst-vundet-paa-danskespildk/
The article is called "Årets næststørste gevinst...".
update:
Just tried this, and it doesnt work, seems like its set elsewhere.
Im not sure if you want Å to be converted to Aa or if you want å to not be converted, but maybe this can point you to your solution:
When you add urlReplacing, all your URL:s doesn´t automagically update (becouse that would be super scary), instead you need to manually Save&Publish for the new Url to be generated for your node.
I've added this urlReplacing in my umbraco.config:
Then, I've created a node called "Årets näst störste gevinst vundet på danskespildk" (i know not exactly what you typed but I wanted to test ÅÄÖ). With the above urlReplacing I get this url (after I Saved and Published):
Glad that it worked out for you Elitent! Happy I could help. :)
I´m not sure about the issue you addressed, but if you think you have found a bug, you can always submit it to http://issues.umbraco.org and someone will eventually fix it (hopefully).
URL problem with Å
Hi there. Just found something odd. When umbraco generates an URL, in my solution, with an å it becomes "aa", but capital Å becomes "å". I'm running 7.5.13, anything I can do to change this?
like this: nyheder/årets-naeststoerste-gevinst-vundet-paa-danskespildk/
update: Just tried this, and it doesnt work, seems like its set elsewhere.
Thanks /Peter
HI Elitent.
Årets näst störste gevinst vundet på danskespildk" (i know not exactly what you typed but I wanted to test ÅÄÖ). With the above urlReplacing I get this url (after I Saved and Published):If you´d want to keep all your ÅÄÖ, add this:
And the URL will be:
But remember, Save&Publish is key here!
I´ve used Umbraco 7.5.12 for this example.
Best of luck to you, have a great day!
EDIT:
Obviously, the following also works with:
Or the other way around, If you dont want to replace them.
Hi Dennis
You are right. It works with save and publish! thanks. :-)
I found out also via a blog post, that I can delete all the content of the urlreplace and only set like this:
Then the url becomes:
/én-god-dag/ => /en-god-dag /Årets-bedste/ => arets-bedste
I wonder why this isnt default in umbraco, I am getting a lot of errors when I validate the URL's as a feed for W3.
Is it possible for someone to create a "feature-change" in the system for this?
Thanks again, Dennis.!
That is awesome! Thanks for sharing! #h5yr
Have a greay day!
Seems its already there from 2013:
http://issues.umbraco.org/issue/U4-1952
I have written some more info on the subject with W3 and urls.
Please ppl vote this up, if anyone gets the chance :-)
/Thanks Peter
That´s great Elitent!
#h5yr
Thank you, your feedback helps Umbraco become even better!
