Site using uSkinned not working after upgrading to 7.6
I have a multilingual website built on 7.5 using a uSkinned theme. I upgraded it today to 7.6, but the front end no longer works. The error being in one of the uSkinned partiaI views, I'm not too sure where it is coming from. Back end works fine.
Anybody upgraded a uSkinned site to the new version?
or it could just be that the websiteConfiugrationNode value isn't set on your settings node in the content section, check the value and republish that node.
I have the same problem. The EnablePropertyValueClonverters is set to true and all website configuration files are republished. this is not helping. I think the problem is in the web.config file
The backend works fine but the frontend gives me the samme problem.
I copied the old web.config back an the site is running.
Now the trick is to find out what in the new web.config that causes the site to crash.
i am still investigating (Winmerge)
Its Likely that is failing becuse the line above settingsFolder is returning null.
This might be because of the inclusion of the Core Property Value converters in 7.6 check .
EnablePropertyValueConvertersis set tofalseinconfig/umbracoSetting.configin thesettings/contentsection of the file. see https://our.umbraco.org/documentation/Getting-Started/Setup/Upgrading/760-breaking-changes#property-value-converters-u4-7318or it could just be that the websiteConfiugrationNode value isn't set on your settings node in the content section, check the value and republish that node.
EnablePropertyValueConverters in UmbracoSettings.config was set to true. Changing it to false did the work. Thanks a lot!
Hi I have the same problem. The EnablePropertyValueClonverters is set to true and all website configuration files are republished. this is not helping. I think the problem is in the web.config file
