  • Dante 7 posts 78 karma points
    May 08, 2017 @ 10:24
    Dante
    Strange behaviour after upgrade from Umbraco 4 to 7
    Hi guys I have a strange behaviour after Umbraco upgrade from 4 to 7, but I don't know if is the standard one.
    When I use the following peace of code:
    umbraco Item ID= Item1 field= testoContenuto runat= server
    and the field "testoContenuto" is blank it take the content from the parent node that have a field with the same name and the content is not blanck.
    How can I always take the content from the node field, also when is blank, and not take the field content from the parent node?
    Thanks in advance. Dante
  • Alex Skrypnyk 6181 posts 24242 karma points MVP 8x admin c-trib
    May 08, 2017 @ 12:48
    Alex Skrypnyk
    Hi Dante
    Recursive attribute set to false:
    <umbraco:Item runat="server" Field="testoContenuto" recursive="false" />
    Alex
    May 08, 2017 @ 13:39
    Dante
    Hi Alex thank you for your support but seems not working in my case.
    It's always getting the content from the parent also using the code you suggested, very strange !!
    Dante.
    May 08, 2017 @ 13:40
    Alex Skrypnyk
    Hi Dante,
    1) try to republish the site
    2) check please, do you have som custom code running?
    /Alex
    May 08, 2017 @ 14:18
    Dante
    Re-published and no custom code. Always the same behavior.
    Dante.
