  • webico 1 post 71 karma points
    May 09, 2017 @ 03:30
    webico
    How to fix No route error when using SurfaceController in Umbraco 7.1.8?
    I am trying to figure out how to get a simple Contact Form SurfaceController working. The problem is that when I try to navigate to the Contact Us page, I get a "No route in the route table matches the supplied values." error.
    My surface controller:
    namespace UmbracoSurface2.Controllers
        public class ContactFormSurfaceController : SurfaceController
            public ActionResult Index()
                return PartialView("ContactForm", new ContactFormViewModel());
    My ContactForm partial:
    @model UmbracoSurface2.Models.ContactFormViewModel
    <form>
        <div class="controls controls-row">
            @Html.TextBoxFor(m => m.Name)
            @Html.TextBoxFor(m => m.Email)
        <div class="controls">
            @Html.TextAreaFor(m => m.Message, new { rows="5" })
            <button id="contact-submit" type="submit" class="btn btn-primary input-medium pull-right">Submit</button>
    </form>
    and my template:
        Layout = "Master.cshtml";
    @Html.Action("Index", "ContactFormController")
    The one big difference between mine and the screencasts and examples I've found is that I'm using Visual Studio 2013 so the ASP.NET Website template has a newer version of MVC which I had to remove to get the UmbracoCms NuGet package to install. I also tried it without adding MVC to the project at the beginning.
    Any help/suggestions would be appreciated,
  • Dave Woestenborghs 3504 posts 12135 karma points MVP 10x admin c-trib
    May 09, 2017 @ 10:26
    Dave Woestenborghs
    hi webico,
    Can you remove this line from your template :
    That way we can determine if it's related to the surface controller or another problem.
    Dave
    May 09, 2017 @ 12:30
    Marc Goodson
    Hi Webico
    I think your Surface Controller is called ContactFormSurfaceController
    and the convention is to remove the word 'Controller' from the name and so to render as an action you would use:
    @Html.Action("Index", "ContactFormSurface")
    otherwise you are saying look for a route on a ContactFormControllerController which doesn't exist hence the route missing error...
    If you want to handle the postback of the form the trick is to have the form elements wrapped in an Html.BeginUmbracoForm
    @using (Html.BeginUmbracoForm("HandlePost", "ContactFormSurface"))
    etc
    then have an action called HandlePost in your surface controller decorated with post:
    [HttpPost]
     public ActionResult HandlePost(YourFormViewModel model)
                if (ModelState.IsValid == false)
                    return CurrentUmbracoPage();
    // else do stuff with posted values
       return RedirectToCurrentUmbracoPage();
