I have the latest version of CMSImport 3.7 running on Umbraco 7.2.5 I am using the Umbraco Data Provider to import data from another Umbraco install of the same version.
Within the source there is a Folder that contains data type instances which have a property, which is MultiNode Treepicker, this property will allow uses to related the instance with another instance in that same folder
When I run CMSImport to import the folder above the instances are a imported but the MultiNode Treepicker property is not set.
I assume the issue is because the property can only be set if the data already exists is there a way to run the import so the property can be set corrrectly and advice would be a great help
CMS Import Not working with MNTP
