  • Rozelle Elson 10 posts 100 karma points
    May 17, 2017 @ 15:22
    Rozelle Elson
    add datatypes to content section on grid layout
    How can I add a datatype that I created into the choose content/insert control section on a grid layout , as per below imageenter image description here
    I would like to add a datatype into this section so I can display it on a grid .
  • Rune Hem Strand 147 posts 911 karma points hq c-trib
    May 17, 2017 @ 15:29
    Rune Hem Strand
    Hi Rozelle
    Grid Editors are not based on datatypes. If you want to add your own you can read more about it in Grid Layout the documentation. Specifically under Grid Editors and Build your own Grid Editor
    If you do want to use datatypes/doctypes you could have a look at the Doc Type Grid Editor package. Alternatively, Le blender might be what you're looking for.
    Hope that helps
    /rune
  • Rhys Mitchell 28 posts 195 karma points
    May 17, 2017 @ 15:32
    Rhys Mitchell
    101
    Hi Rozelle,
    There's Umbraco Documentation on this over here. After following the steps outlined in this tutorial, you will have a new property to add to your Grid Layout.
    You "can" avoid using Angular altogether by making use of a great package called LeBlender.
    Not quite the same thing, but there's some good documentation here as well for creating property editors. They are mostly the same in their make-up, so you should find plenty of take-away's from those articles.
    May 17, 2017 @ 15:41
    Rozelle Elson
    Hi Rune
    Thank you for your help . I will have a look at that and see what I can do , I think the LeBlender package looks like a good option
    Thanks Roz
    May 19, 2017 @ 14:36
    Rozelle Elson
    I have installed LeBlender and have created some grid editors such as a carousel , by following the videos but when it displays on the page , I get the following error message , can you help with this ?
    The partial view '/views/partials/grid/editors/Carousel.cshtml' was not found or no view engine supports the searched locations. The following locations were searched: /views/partials/grid/editors/Carousel.cshtml
    May 19, 2017 @ 22:09
    Alex Skrypnyk
    Hi Rozelle
    I think you have to create '/views/partials/grid/editors/Carousel.cshtml' and do some razor coding for make it works. Look please for LeBlender documentation, there is some example how to render data in Razor.
    Alex
