I just set up a clean installation of Umbraco 7.6.1 on VS2015 Professional and after starting umbraco in visual-studio-debug-modus I tried to install the merchello-package over the umbraco-inside package-manager in the developer section.
But everytime I hit the "Install Package"-button nothing happends but I redirect to the package-list.
I tried some other packages and also another Pc with VS2015 but all the same.
In VS2013 all is functioned.
Can anybody confirm this?
Is this a known problem?
I can tell you I am having the same problem when I try to install the KS.Umbraco7.Calendar package while running in debug on VS2017. I have the same site published to my hosting environment, and it works fine. Still hunting for a solution for local install to my dev environment.
I'm still having this problem with other packages. In fact any package I try. I have tried changing the write permissions on the local folders to everyone has full access. Still have the problem.
So in case someone is having the same problem, I ended up having to set up a site in IIS, just to install packages. There were a number of issues I had to work through that I think related to running IIS on windows 10. the following blog post would be helpful to someone whos not used to managing IIS.
Problem with VS2015 and Packages
Hello, I just set up a clean installation of Umbraco 7.6.1 on VS2015 Professional and after starting umbraco in visual-studio-debug-modus I tried to install the merchello-package over the umbraco-inside package-manager in the developer section. But everytime I hit the "Install Package"-button nothing happends but I redirect to the package-list. I tried some other packages and also another Pc with VS2015 but all the same.
Can anybody confirm this? Is this a known problem?
Greetings Marko
http://www.paulrgriffiths.co.uk/blog/installing-umbraco-7-part-3-setting-up-iis-file-permissions/
Sure wish I could figure out the issue with getting it to run in the debugger.
