  • Mike Masey 39 posts 253 karma points MVP 6x c-trib
    May 26, 2017 @ 08:31
    Mike Masey
    Security issue question
    Does anyone know if the issues raised in this post from 2014 are still relevant for Umbraco 7?
    https://umbraco.com/blog/security-issues-found-in-umbraco-4-6-and-7/
    If there are any core team reading this, would you be able to update it to clarify whether any action is required for the newer versions of Umbraco.
    Thanks in advance, H5YR!
    May 26, 2017 @ 12:00
    Sebastiaan Janssen
    Thanks, I've updated the notes here to indicate that both issues were fixed for the next releases (6.2.2 and 7.1.7 respectively) so new releases since that blog post would not be affected by this issue. We would never release a new version with known security issues in it.
    For proxy.htm it is important that you do check if the content is the same as in the github commit that's mentioned in the blog post, if an upgrade did not replace this file you might still be vulnerable. The booting.aspx issue was fixed in a dll so that should be up-to-date already else you would be seeing errors all over the place.
    May 26, 2017 @ 12:48
    Mike Masey
    Brilliant, thanks a lot for the update Seb.
