  • sohail 5 posts 75 karma points
    May 29, 2017 @ 07:35
    sohail
    Umbraco Backend issue when setting up Umbraco API with Dependency Injection (Auto fac)
    Hello Everyone,
    I have set up my IOC using autofac for the Dependency Injection, then I am able to resolve dependencies in my controllers as shown in this post
    https://our.umbraco.org/forum/developers/api-questions/41794-Web-API-UmbracoApiController-does-not-use-DependencyResolver?p=1
    It's working fine, but the problem is when i logged into the umbraco backend i got this error.
    https://www.screencast.com/t/f54kNM9SN7J
    I am using Umbraco 7.6.1 please help me out.
    May 29, 2017 @ 07:44
    Dave Woestenborghs
    Hi Sohail,
    You problably need to register the Umbraco Api Controllers
    builder.RegisterApiControllers(typeof(UmbracoApplication).Assembly);
    Dave
    May 30, 2017 @ 07:39
    sohail
    Hi Dave,
    Yes, I have registered the Umbraco API Controllers and it's working fine. API controller received my requests and dependency Injection also applied but the problem is whenever, I tried to login to Umbraco Backend its give me this error see the screenshot which is mention below :
    It will not render any tree and other Umbraco related stuff.
    protected override void ApplicationStarted(UmbracoApplicationBase umbracoApplication, ApplicationContext applicationContext)
                var builder = new ContainerBuilder();
            //Register our controllers from this assembly with Autofac
            builder.Register(c => UmbracoContext.Current).AsSelf();
            builder.RegisterInstance(ApplicationContext.Current).AsSelf();
            builder.RegisterControllers(Assembly.GetExecutingAssembly());
            //builder.RegisterApiControllers(typeof(UmbracoApplication).Assembly);
            builder.RegisterApiControllers(Assembly.GetExecutingAssembly());
            //Register types
            builder.RegisterType<DataFactory>().As<IDataFactory>();
            builder.RegisterAssemblyTypes(typeof(HeaderRepository).Assembly)
           .Where(t => t.Name.EndsWith("Repository"))
           .AsImplementedInterfaces().InstancePerRequest();
            builder.RegisterAssemblyTypes(typeof(HeaderService).Assembly)
           .Where(t => t.Name.EndsWith("Service"))
            //Set up MVC to use Autofac as a dependency resolver
            var container = builder.Build();
            var resolver = new AutofacWebApiDependencyResolver(container);
            GlobalConfiguration.Configuration.DependencyResolver = resolver;
            DependencyResolver.SetResolver(new AutofacDependencyResolver(container));
    May 30, 2017 @ 07:44
    Dave Woestenborghs
    Hi Sohail,
    The line to register the Umbraco Api controllers is in comments in the code you posted. Maybe that's the issue ?
    May 31, 2017 @ 08:02
    May 31, 2017 @ 08:13
    Dave Woestenborghs
    Hi Sohail,
    Can you mark the answer as a solution. So others can find it easier.
    Dave
