We've upgraded from v7.2.2 to 7.6.1, and we're getting an error in the Umbraco backoffice, where a date picker exists in a custom dashboard.
We've implmented a datetimepicker, which you can see here.
The error we're seeing is: $element.find(...).datetimepicker is not a function.
Google search seems to suggest that JQuery should be loaded first, which in the install.loader.js, it is..
LazyLoad.js( [ 'lib/jquery/jquery.min.js', /* 1.1.5 */ 'lib/angular/1.1.5/angular.min.js', 'lib/angular/1.1.5/angular-cookies.min.js', 'lib/angular/1.1.5/angular-mobile.min.js', 'lib/angular/1.1.5/angular-mocks.js', 'lib/angular/1.1.5/angular-sanitize.min.js', 'lib/underscore/underscore-min.js', 'js/umbraco.installer.js', 'js/umbraco.directives.js' ], function () { jQuery(document).ready(function () { angular.bootstrap(document, ['ngSanitize', 'umbraco.install', 'umbraco.directives.validation']); }); } );
Any thoughts..?
Q: How did you upgrade? Nuget/Manual
Have you tried changing version number in the clientdependency config file
We did a NuGet upgrade - although updating client dependency didn't help.
Hi Jason,
How did you fix this? I have the same issue after updating.
cheers,
Mark
$element.find(...).datetimepicker is not a function.Google search seems to suggest that JQuery should be loaded first, which in the install.loader.js, it is..
Any thoughts..?
Hi Jason,
cheers,
Mark
