  • Bo Jacobsen 610 posts 2409 karma points
    Jun 02, 2017 @ 08:56
    Bo Jacobsen
    ExamineInspectorDashboard.ascx could not be loaded
    using umbraco v 4.11.1 (Assembly version: 1.0.4715.27659).
    Could not load control: '/umbraco/plugins/ExamineInspector/ExamineInspectorDashboard.ascx'. Error message: System.Web.HttpParseException (0x80004005): Could not load type 'ExamineInspector.Umbraco.Plugins.ExamineInspector.UserControls.DashBoardContainer'. ---> System.Web.HttpParseException (0x80004005): Could not load type 'ExamineInspector.Umbraco.Plugins.ExamineInspector.UserControls.DashBoardContainer'. ---> System.Web.HttpException (0x80004005): Could not load type 'ExamineInspector.Umbraco.Plugins.ExamineInspector.UserControls.DashBoardContainer'. at System.Web.UI.TemplateParser.GetType(String typeName, Boolean ignoreCase, Boolean throwOnError) at System.Web.UI.TemplateParser.ProcessInheritsAttribute(String baseTypeName, String codeFileBaseTypeName, String src, Assembly assembly) at System.Web.UI.TemplateParser.PostProcessMainDirectiveAttributes(IDictionary parseData) at System.Web.UI.TemplateParser.ProcessException(Exception ex) at System.Web.UI.TemplateParser.ParseStringInternal(String text, Encoding fileEncoding) at System.Web.UI.TemplateParser.ParseString(String text, VirtualPath virtualPath, Encoding fileEncoding) at System.Web.UI.TemplateParser.ParseString(String text, VirtualPath virtualPath, Encoding fileEncoding) at System.Web.UI.TemplateParser.ParseFile(String physicalPath, VirtualPath virtualPath) at System.Web.UI.TemplateParser.ParseInternal() at System.Web.UI.TemplateParser.Parse() at System.Web.Compilation.BaseTemplateBuildProvider.get_CodeCompilerType() at System.Web.Compilation.BuildProvider.GetCompilerTypeFromBuildProvider(BuildProvider buildProvider) at System.Web.Compilation.BuildProvidersCompiler.ProcessBuildProviders() at System.Web.Compilation.BuildProvidersCompiler.PerformBuild() at System.Web.Compilation.BuildManager.CompileWebFile(VirtualPath virtualPath) at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate) at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate) at System.Web.UI.TemplateControl.LoadControl(VirtualPath virtualPath) at umbraco.cms.presentation.dashboard.OnInit(EventArgs e)
    The file is there and i have tried to clear everything from the Temp folder. Any idear?
    Jun 02, 2017 @ 09:02
    Ismail Mayat
    Bo,
    I dont think it will work with Umbraco 4.11 when I made it I did it with version 6.
    A v7 is in the pipeline should be out soon.
    Regards
    Ismail
    Jun 02, 2017 @ 13:04
    Bo Jacobsen
    Thanks for the reply Ismail.
