  • Tony Thompson 18 posts 90 karma points
    Jun 05, 2017 @ 08:48
    Tony Thompson
    "Login failed for user" after enabling SSL
    There are lots of threads similar to this issue but none that really match my situation.
    Problem: I can login fine to the administration area when using http, but if I use https it tells me that "Login failed for user
    I am using a FQDN to access the back end (not an IP address)
    What do I need to do?
    Thx
    Jun 05, 2017 @ 15:03
    Alex Skrypnyk
    Hi Tony
    Do you have this key in AppSettings?
    <appSettings>
      <add key="umbracoUseSSL" value="true" />
    </appSettings>
    Jun 05, 2017 @ 15:50
    Tony Thompson
    Thanks Alex.
    When I set it to "true" it returned an error page:
    ERRTOOMANY_REDIRECTS
    Sounds like I have a configuration problem somewhere else?
