7.6.3 Native components of SQL Server Compact engine are not loaded.
I have created 12 different websites in the past 12 months on this machine and my home machine with no issues.
Today I have downloaded a new copy of 7.6.3, unzipped it, fired it up in Visual Studio 2015 and I make it to where the installer attempts to create the database and it fails with native components can't be found.
I've removed SQL Server CE 4.0 from my machine, installed SQL Server CE 4 SP1, installed SQL Server CE 3.5 SP2 (is on my home machine) and I cannot get an instance of Umbraco 7.6.3 fired up.
Visual Studio Error
An unhandled exception of type 'System.Data.SqlServerCe.SqlCeException' occurred in System.Data.SqlServerCe.dll
Additional information: Native components of SQL Server Compact engine are not loaded. Please reinstall Microsoft SQL Server Compact.
Page error
Unable to load the native components of SQL Server Compact corresponding to the ADO.NET provider of version 8902. Install the correct version of SQL Server Compact. Refer to KB article 974247 for more details.
Exception Details: System.Data.SqlServerCe.SqlCeException: Unable to load the native components of SQL Server Compact corresponding to the ADO.NET provider of version 8902. Install the correct version of SQL Server Compact. Refer to KB article 974247 for more details.
So I went to that KB article and it's saying to ensure you have the right version, well according to the web.config the right version is 4.0....and I have it.
I am having a same problem while upgrading from 7.4.3 to 7.5.0
and I cannot get an instance of Umbraco 7.5.0 fired up. Additional information in my case is that, I took copy of 7.4.3 from my production server (Window Server 2012).
Still nothing, I got my project to work on my laptop at work, commited it all, pulled it down to my desktop and now I get the same error, I've compared DLL file versions and installed SQL Server Compact versions and the machines are identical.
I've tried both methods, Nuget AND downloading the zip. I finally got it working (Via the downloaded Zip) but all I did was Uninstall SQL Server Compact 4.0 SP1 x64 on each machine and reinstalled it by downloading it from Microsoft.
Visual Studio Error
Page error
What am I missing?
I even manually copied the Native components over, still no go.
I am having a same problem while upgrading from 7.4.3 to 7.5.0 and I cannot get an instance of Umbraco 7.5.0 fired up. Additional information in my case is that, I took copy of 7.4.3 from my production server (Window Server 2012).
are you using nuGet?
