  • Dean Bullock 4 posts 106 karma points
    Jun 15, 2017 @ 14:05
    Dean Bullock
    Grid Layout - New Row Configuration Not Working
    I am having problems adding new row configurations to existing Grid Layouts.
    This on a clean install of Umbraco version 7.6.3
    To replicate the issue try adding new row configurations to an existing grid layout data type.
    Then go to the appropriate content page and add the new row to the page grid layout.
    If you keep adding new row configurations to the data type it seems add the wrong row config to the content.
    Is this a bug or known issue?
    It looks similar to this issue: https://our.umbraco.org/forum/umbraco-7/using-umbraco-7/64304-New-Row-Configuration-not-Showing
    Thanks, Dean
    Jun 16, 2017 @ 09:00
    Dean Bullock
    101
    I've found a workaround. Make sure the row configuration has both a Label and Name and that the checkboxes are checked in "allow all row configurations" under the layout.
    Adding Row Configuration
  • Michael Taylor 5 posts 75 karma points
    Feb 09, 2018 @ 14:42
    Michael Taylor
    Thanks! This worked for me (setting a name as well). This wasn't an issue in previous versions though, only since installing 7.8.0.
