  • Jonas 123 posts 206 karma points
    Jun 19, 2017 @ 07:28
    Jonas
    Pick node outside of Users startnode
    We have a multi site installation. We want the users to be able to pick content outside of their own start node.
    Typically User has Site1 as startnode and wants to be able to pick content from Mastercontent
    • Mastercontent
    • Site1
    • Site2
    • Site3
    Jun 19, 2017 @ 20:09
    Marc Goodson
    Hi Jonas
    You could either let everyone have start nodes at the top of the site tree, and use user permissions to prevent users from browsing Site2, Site3 etc
    or
    you could have a look at this package:
    https://our.umbraco.org/projects/backoffice-extensions/multiple-start-nodes/
    that enables multiple start nodes to be defined.
    regards
    marc
    Jun 28, 2017 @ 09:07
    Jonas
    Hi, looked at that Plugin, but cannot get it to work.
    Jun 29, 2017 @ 21:24
    Marc Goodson
    Hi Jonas
    Problems installing ?
    or setting the start nodes ?
    or are the different start nodes not honoured correctly when picking ?
    Have you tried to use User Permissions to control what each user has access to instead of the start node?
    regards
    Marc
    Jun 30, 2017 @ 06:52
    Jonas
    Hi Marc, Installation works fine. But when I pick new startnodes. User permissions is ok on the folder I am trying to use. Since we have like 100 users it is not an option to use permissions instead of startnode. enter image description here
    When using the plugin like this I see all of the folders that the user is not supposed to see.
