  • Anders 13 posts 133 karma points
    Jun 19, 2017 @ 19:45
    Anders
    Guide to publishing / deploying umbraco site
    Hi All :)
    I have created a local umbraco site with Visual Studio, and now I am having some challenges publishing / deploying the site.
    The local solution is build on a CE SQL, and I have a domain at Unoeuro.com with a MS SQL database.
    Have any of you guys found a good simple Guide?
    I guess it's not just a few clicks to deploy.
    I found a lot of other posts regarding the same problem, but I haven't been able to find a post with a good up-to-date solution.
  • emma burstow 43 posts 251 karma points MVP 3x hq c-trib
    Jun 21, 2017 @ 14:12
    emma burstow
    2
    Hi there,
    I really struggled deploying my first umbraco site and spent a long old time googling. This guide, elsewhere in the forum helped me the most though.
    https://our.umbraco.org/forum/getting-started/installing-umbraco/46540-How-to-install-Umbraco-700-on-GoDaddy-Plesk-Hosting
    It was for Plesk, which I was using, but plenty of what he describes would (I assume) need to happen for other platforms too, such as the permissions settings on particular folders.
    I also needed to convert the db from SQL CE to MySQL for the hosting - I used an online tool for that and I was quite surprised when it really worked.
    I hope this helps, a lot of it was fumbling for me. If you do find a better resource, do point me in the right direction!
    Emma
  • Brett Fullam 119 posts 629 karma points
    Jun 21, 2017 @ 14:34
    Brett Fullam
    Hi Anders,
    This video by Paul Seal, another umbraco developer who's actually quite active in this forum, did it for me ... here's a video where he shows you step by step how to publish and then deploy the site using an umbraco site as his specific example:
    "How to deploy an ASP.NET website using Umbraco as an example" https://www.youtube.com/watch?v=vAq9NC0rp7U
    I highly recommend you check out his blog and youtube channel ... lots of good Umbraco information.
    I also had to convert my database from SQL CE to SQL ... took me a while to find out how to do it, but it's relatively simple and you can do it right inside of Visual Studio too. I can share this method with you if you need it too.
    Jun 21, 2017 @ 14:38
    emma burstow
    I've just had a good read of your post about converting the DB! Thanks for the tip off - I'll subscribe to Paul's channel. #h5yr
    Em
    Jun 24, 2017 @ 17:32
    Anders
    Hi Emma and Brett
    Thank you for answering my question.
    I tried to convert from SQL CE to MS SQL, but I didn't have any succes with it, so I ended up making a whole new project, where I used the MS SQL database from start.
    It actually turned out, that it made it much easier to publish my project. I just went into Build -> Publish Project Name -> Typed in the connection settings from my hosting provider, and filled the Destination Connection String (using the wizard in Visual Studio). Bang, and it worked like a charm !
    So from now on, I'm definitely going to use MS SQL on future projects.
    Btw it took me 2 hours making a new project, based on the old one. Reused the views, and copy pasted a lot.
    Thanks for the about: http://www.codeshare.co.uk/ He made a lot of good stuff !
    Thanks again, both of you ! :)
