  • Joe Qureshi 3 posts 73 karma points
    Jun 20, 2017 @ 20:01
    Joe Qureshi
    Umbraco not publishing changes unless application pool reset.
    When I make any changes to even empty sites the changes only go through once I have reset the application pool.
    Setting fcnMode to disabled works, however it takes much longer than it should.
    This is a clean install, using visual studio -> IIS express on windows 10.
    Jul 14, 2017 @ 10:42
    Alex Skrypnyk
    Hi Joe
    What is the code of your page? Can you share views code?
    Maybe some macro caching?
    Alex
    Jul 17, 2017 @ 09:33
    Alex Skrypnyk
    Hi Joe
    Did you find what was the problem?
    Alex
    Jul 24, 2017 @ 13:43
    Joe Qureshi
    Sorry for the late reply.
    I tried multiple fresh installs on a windows 10 virtual machine (parallels) using a shared drive.
    0 code was added and the problem persisted regardless of whether I was doing it on Windows/Mac side.
    I followed a few guides on using Visual Studio & IIS Express to make it so my Mac side could use the same localhost.
    In the end I stopped using Umbraco and switched to a different CMS.
