  • Malte 7 posts 107 karma points
    Jun 27, 2017 @ 08:45
    Malte
    UmbracoApiController and Custom AntiForgeryToken Validator
    im currently developing a Web Application with Umbraco and Angular. I would like to secure my input Fields with the Microsoft AntiForgeryToken, i was able to create this Token, but unable to Validate it. I added a custom AntiForgeryTokenValidator to the UmbracoApiController
    namespace Project.Controllers.APIs
        [AdfsAuthorize]
        [MyValidateAntiForgeryToken]
        public class HelperApiController : UmbracoApiController
    But this Validator is not getting called.
    using System;
    using System.Web;
    using System.Web.Helpers;
    using System.Web.Mvc;
    using static System.String;
    namespace Project.Filters
        [AttributeUsage(AttributeTargets.Class | AttributeTargets.Method, AllowMultiple = false, Inherited = true)]
        public class MyValidateAntiForgeryTokenAttribute : FilterAttribute, IAuthorizationFilter
            private void ValidateRequestHeader(HttpRequestBase request)
                var cookieToken = Empty;
                var formToken = Empty;
                var tokenValue = request.Headers["RequestVerificationToken"];
                if (!IsNullOrEmpty(tokenValue))
                    var tokens = tokenValue.Split(':');
                    if (tokens.Length == 2)
                        cookieToken = tokens[0].Trim();
                        formToken = tokens[1].Trim();
                AntiForgery.Validate(cookieToken, formToken);
            public void OnAuthorization(AuthorizationContext filterContext)
                try
                    if (filterContext.HttpContext.Request.IsAjaxRequest())
                        ValidateRequestHeader(filterContext.HttpContext.Request);
                    else
                        AntiForgery.Validate();
                catch (HttpAntiForgeryException e)
                    throw new HttpAntiForgeryException("Anti forgery token cookie not found");
    The same applies to the the AdfsAuthorize Attibute.
    The Project is currently on Umbraco 7.5.2.
    Do you guys have any idea or possible solution for me?
    Best regards from Germany
    Malte
  • David Brendel 792 posts 2970 karma points MVP 3x c-trib
    Jun 27, 2017 @ 18:45
    David Brendel
    Hi Malte,
    I'm using the folling attribute to do custom antiforgery validation:
    [AttributeUsage(AttributeTargets.Method | AttributeTargets.Class, AllowMultiple = false, Inherited = true)]
    internal sealed class ValidateHttpAntiForgeryTokenAttribute : FilterAttribute, IAuthorizationFilter
        public Task<HttpResponseMessage> ExecuteAuthorizationFilterAsync(HttpActionContext actionContext, CancellationToken cancellationToken, Func<Task<HttpResponseMessage>> continuation)
            HttpRequestMessage request = actionContext.Request;
            try
                if (IsAjaxRequest(request))
                    ValidateRequestHeader(request);
                else
            catch (Exception ex)
                LogHelper.Error<ValidateHttpAntiForgeryTokenAttribute>(ex.Message, ex);
                actionContext.Response = new HttpResponseMessage
                    StatusCode = HttpStatusCode.Forbidden,
                    RequestMessage = actionContext.ControllerContext.Request
                return FromResult(actionContext.Response);
            return continuation();
        private Task<HttpResponseMessage> FromResult(HttpResponseMessage result)
            var source = new TaskCompletionSource<HttpResponseMessage>();
            source.SetResult(result);
            return source.Task;
        private bool IsAjaxRequest(HttpRequestMessage request)
            IEnumerable<string> xRequestedWithHeaders;
            if (request.Headers.TryGetValues("X-Requested-With", out xRequestedWithHeaders))
                string headerValue = xRequestedWithHeaders.FirstOrDefault();
                if (!String.IsNullOrEmpty(headerValue))
                    return String.Equals(headerValue, "XMLHttpRequest", StringComparison.OrdinalIgnoreCase);
            return false;
        private void ValidateRequestHeader(HttpRequestMessage request)
            var headers = request.Headers;
            var cookie = headers
                .GetCookies()
                .Select(c => c[AntiForgeryConfig.CookieName])
                .FirstOrDefault();
            IEnumerable<string> xXsrfHeaders;
            if (headers.TryGetValues("X-XSRF-Token", out xXsrfHeaders))
                var rvt = xXsrfHeaders.FirstOrDefault();
                if (cookie == null)
                    throw new InvalidOperationException(String.Format("Missing {0} cookie", AntiForgeryConfig.CookieName));
                AntiForgery.Validate(cookie.Value, rvt);
            else
                var headerBuilder = new StringBuilder();
                headerBuilder.AppendLine("Missing X-XSRF-Token HTTP header:");
                foreach (var header in headers)
                    headerBuilder.AppendFormat("- [{0}] = {1}", header.Key, header.Value);
                    headerBuilder.AppendLine();
                throw new InvalidOperationException(headerBuilder.ToString());
    Maybe that helps.
    Regard David
    Jun 29, 2017 @ 08:07
    Malte
    Hi David,
    thanks for your response. The Problem now is that VS is saying this method is missing:
        throw new NotImplementedException();
    How do i wire this up correctly?
    Regards Malte
    Aug 04, 2017 @ 09:10
    Malte
    Hi all,
    @Marcel Wege found the Problem, it was due to the fact that i used
    public class MyValidateAntiForgeryTokenAttribute : System.Web.Mvc.Filters.FilterAttribute, System.Web.Mvc.Filters.IAuthorizationFilter
    after i change the FilterAttribute namespace to
    public class MyValidateAntiForgeryTokenAttribute : System.Web.Http.Filters.FilterAttribute, System.Web.Http.Filters.IAuthorizationFilter
    it all worked fine.
