  • Mattia 6 posts 77 karma points
    Jul 06, 2017 @ 10:13
    Mattia
    Guid Issue
    Hi!
    I'm trying to get the GUID of a published node of my umbraco tree in my surface controller.
    I have the node ID.
    After calling (successfully) umbracoHelper.TypedContent(myId) i tried to get my key using GetKey() but it always return 0.
    Any idea? The node is published, i can see his guid in my backend .
    Umbraco version -> 7.6.3.
    Thanks.
    Jul 06, 2017 @ 11:40
    Alex Skrypnyk
    Hi Mattia
    Try this code:
    var contentWithKey = content as IPublishedContentWithKey;
    return contentWithKey == null ? Guid.Empty : contentWithKey.Key;
    Or add this method to your solution:
    public static Guid GetGuid(this IPublishedContent content)
        if (contentWithKey != null)
            return contentWithKey.Key;
        if (content is PublishedContentWrapped)
            contentWithKey = ((PublishedContentWrapped)content).Unwrap() as IPublishedContentWithKey;
        return Guid.Empty;
    Alex
    Jul 06, 2017 @ 12:09
    Mattia
    Already tried, but return contentWithKey == null ? Guid.Empty : contentWithKey.Key; returns always Guid.Empty AKA contentWithKey seems to be null...
    Jul 06, 2017 @ 12:40
    Alex Skrypnyk
    It's not right way to do it, but it works:
    var node = ApplicationContext.Services.ContentService.GetById(1111);
    var guid = node.GetUdi().Guid;
    Jul 06, 2017 @ 14:16
    Sebastiaan Janssen
    2
    No no no no no please do not do this!!
    This call goes straight to the database and circumvents the content cache. This is very slow and very bad for performance!
    Please don't do this, ever. Unless you know what you're doing.
    Anyway, have you tried this? https://github.com/Shazwazza/Articulate/blob/master/src/Articulate/Models/PublishedContentExtensions.cs#L52
    It looks similar to the method above, but I can't figure out Mattia what exactly is null for you, the code on which line?
    Jul 06, 2017 @ 14:27
    Alex Skrypnyk
    Just tested this method on Umbraco 7.6.3, and it works.
        return Guid.Empty;
    Jul 06, 2017 @ 12:41
    Mattia
    Yes, I found the same work-around.... But i would prefer not to user the content service
  • Nik 1625 posts 7295 karma points MVP 8x c-trib
    Jul 06, 2017 @ 15:24
    Nik
    2
    Alex's example where he uses the Unwrap method is what I've also found you have to do. Most of the time GetKey on IPublishedContent doesn't work you have to unwrap it rather than cast it to IPublishedContentWithKey to get it to behave.
