  • Poornima Nayar 106 posts 276 karma points MVP 6x c-trib
    Jul 10, 2017 @ 08:09
    Poornima Nayar
    How to index and use the new content pickers and MNTP
    I am using the new MNTP to work as tags for my document type and I want to implement a filter functionality based on these tags. There can be multiple filters in the search query. I have been looking at the index and I see that the MNTP stores values as umb://document/xxxxxxxx . Whats the best way to store and query the index in this case to achieve filtering?
    Poornima
    Jul 10, 2017 @ 08:16
    Ismail Mayat
    Poornima,
    How does it store multiple values as a csv list? I would look at may be using gathering node data and then either create a new field and get the values. if they are csv then split on string. Then I would look at extracting out the guids from the urls and storing those as space separated list.
    On you page with tags you can get the guid of the tag and then search on that?
    It's a good point you have here im going to update my examine course notes.
    Regards
    Ismail
    Jul 10, 2017 @ 08:31
    Poornima Nayar
    Hi Ismail,
    I was going to do just what you said but I wanted to make sure that what I do is right as the entire site is more or less examine powered. I ll let you know how it goes.
    Poornima
    Jul 17, 2017 @ 12:36
    Poornima Nayar
    Hi Ismail,
    Sorry for delayed response. This is what I finally got to.
     if (e.Fields.ContainsKey("category"))
                                e.Fields.Add(
                                    "categories-combined",
                                    string.Concat(e.Fields["category"].Replace("umb://document/", string.Empty), " "));
    I also wanted to ask you one more thing. Is it a good practice to further select from search results using LINQ once I have the search results?
    Poornima
  • The Cogworks 3 posts 394 karma points
    Jul 17, 2017 @ 15:22
    The Cogworks
    Poornima,
    Try and avoid using extra linq statements at end use the examine itself to filter as it will be much quicker.
    Regards
    Ismail
    Jul 17, 2017 @ 21:14
    Poornima Nayar
    Hi Ismail,
    What I wanted to to was get the search results and I am interested in particular fields from the set.
    say for eg i need to get a list of document types "xyz". from that list I need all fields of type "abc".
    Poornima
