Hello
I defined a documenttype (using uSiteBuilder) and everything works correctly.
But if I try to define a new property of type "ContentPicker", I receive a 500 error in runtime.
Can anyone help me?
You can see the error below
Source Error:
Stack Trace:
Vega.USiteBuilder.Util.AddPropertyType(IContentTypeBase contentType, DataTypeDefinition dt, String alias, String name, String tabName) +41
Vega.USiteBuilder.ManagerBase.SynchronizeContentTypeProperties(Type typeContentType, IContentType contentType, DocumentTypeAttribute documentTypeAttribute, Boolean& hadDefaultValues, Boolean updateMixins) +613
Vega.USiteBuilder.DocumentTypeManager.SynchronizeDocumentType(Type typeDocType, Type baseTypeDocType) +934
Vega.USiteBuilder.DocumentTypeManager.SynchronizeDocumentTypes(Type baseTypeDocType) +114
Vega.USiteBuilder.DocumentTypeManager.Synchronize() +461
Vega.USiteBuilder.UmbracoManager.Synchronize() +159
Vega.USiteBuilder.UmbracoManager.SynchronizeIfNotSynchronized() +127
System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +138
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +90
Problem with property ContentPicker
Hello I defined a documenttype (using uSiteBuilder) and everything works correctly. But if I try to define a new property of type "ContentPicker", I receive a 500 error in runtime. Can anyone help me? You can see the error below
Server Error in '/' Application. Object reference not set to an instance of an object. Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Source Error:
Stack Trace:
[NullReferenceException: Object reference not set to an instance of an object.] Vega.USiteBuilder.Util.AddPropertyType(IContentTypeBase contentType, DataTypeDefinition dt, String alias, String name, String tabName) +41 Vega.USiteBuilder.ManagerBase.SynchronizeContentTypeProperties(Type typeContentType, IContentType contentType, DocumentTypeAttribute documentTypeAttribute, Boolean& hadDefaultValues, Boolean updateMixins) +613 Vega.USiteBuilder.DocumentTypeManager.SynchronizeDocumentType(Type typeDocType, Type baseTypeDocType) +934 Vega.USiteBuilder.DocumentTypeManager.SynchronizeDocumentTypes(Type baseTypeDocType) +114 Vega.USiteBuilder.DocumentTypeManager.Synchronize() +461 Vega.USiteBuilder.UmbracoManager.Synchronize() +159 Vega.USiteBuilder.UmbracoManager.SynchronizeIfNotSynchronized() +127 System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +138 System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +90
