  • siko 24 posts 77 karma points
    Jul 17, 2017 @ 13:08
    siko
    .GetCropUrl works, and then it doesnt
    I must be missing something obvious, but GetCropUrl works:
        var imageNode = Model.Content.GetPropertyValue<IPublishedContent>("slideImage");
        string imgUrl = imageNode.GetCropUrl("blog post");
    <img src="@imgUrl" alt="">
    <a class="overlay-link popup-img" href="@imgUrl"><i class="fa fa-search-plus"></i></a>
    @Model.Content.GetPropertyValue("slideContent")
    And then in another view, it doesn't
                @foreach (var solution in CurrentPage.Children())
                    var imageNode = solution.GetPropertyValue<IPublishedContent>("bannerImage");
    I don't 'get' it... maybe someone can shed some light?
    Jul 17, 2017 @ 13:10
    Alex Skrypnyk
    Hi Siko
    Try this code:
    @foreach (var solution in Model.Content.Children())
    The problem in your code is that "CurrentPage" is dynamic type in this line:
    Alex
    Jul 17, 2017 @ 18:13
    siko
    Thanks. I found it and yes, you are right!
